I keep trying to export my part as an stl but it keeps failing. Ive broken up the project into parts and each part fails to export.
Hey @ac.eleet ,
Sorry that you’re having some difficulties. A couple of questions and suggestions for you
- What is the error message that you’re receiving when you try to export. If your KCL has any errors (including engine errors). You won’t be able to export
- Assuming that you don’t have any errors, have you tried exporting to different formats like STEP or OBJ?
Regards,
Ryan
