Hi,
A few days ago I was able to use this prompt to generate the correct model. (1st image)
- make a rectangle, side A=80mm long, side B=25mm, side C=16mm. The top of side A x B has a 5mm diameter hole through it. Side B x C has two holes, each 12.5mm diameter and 10mm from each end.
No, when I generate it again using the same promp, I get something different (2nd image).
I’ve since spent a lot of time with a very detailed description (and some $ now) to try and generate my first result, but to no avail. eg.
- make a rectangular block, with side lengths x,y,z = (80,25,16). On the top at x,y = (40,12.5) there’s a 5mm diameter hole. On the side of the rectangle (80,16) at x,z = (9.75,8) is a 10.25mm diameter hole. On the side of the rectangle (80,16) at x,z=(70.25,8) is a 10.25mm diameter hole.
Has something changed? Ugh, I can only upload one new image as a new user…
