Import STEP file failed
Hi,
I’ve tried to import a STEP file. This is quite important for me to import some existing design for incremental change in Zookeeper. But Zookeeper responded import failed without any detail information. Can you please help to check? I tried to upload the STEP file here, but it’s not allowed. I paste some header lines from the STEP file in this window.
Thank you.
Best regards,
Julian
ISO-10303-21;
HEADER;
FILE_DESCRIPTION((‘STEP AP214’),‘1’);
FILE_NAME(‘5blp2x0h8zxm.stp’,‘2026-05-15T00:46:02’,(’ ‘),(’ ‘),‘Spatial InterOp 3D’,’ ‘,’ ‘);
FILE_SCHEMA((‘automotive_design’));
ENDSEC;
DATA;
#1=MECHANICAL_DESIGN_GEOMETRIC_PRESENTATION_REPRESENTATION(’ ‘,(),#6);
#2=PRODUCT_DEFINITION_CONTEXT(’‘,#7,‘design’);
#3=APPLICATION_PROTOCOL_DEFINITION(‘INTERNATIONAL STANDARD’,‘automotive_design’,1994,#7);
#4=PRODUCT_CATEGORY_RELATIONSHIP(‘NONE’,‘NONE’,#8,#9);
#5=SHAPE_DEFINITION_REPRESENTATION(#10,#11);
#6= (GEOMETRIC_REPRESENTATION_CONTEXT(3)GLOBAL_UNCERTAINTY_ASSIGNED_CONTEXT((#12))GLOBAL_UNIT_ASSIGNED_CONTEXT((#13,#14,#15))REPRESENTATION_CONTEXT(‘NONE’,‘WORKSPACE’));
#7=APPLICATION_CONTEXT(’ ');
Hello,
I can look into why the STEP file import is failing. I will start a support request. You should receive an email where you can share the STEP file in a private thread.
Best,
Cameron
Hi Cameron,
Is there any update on this issue? I have the STEP files ready. Please let me know how I can provide the files for you.
Thank you very much for the prompt support.
Best regards,
Julian
Hi Julian,
You should have received an email from us about the issue and can attach the STEP files there.
If you are unable to find the email, you can open a new request here: Contact Us | Zoo then reply with the attached files.
Best,
Cameron
Hi Cameron,
Sorry that the email was filtered as SPAM.
I have replied the email with the STEP files.
Please help to check.
Thank you very much for the prompt response.
Best regards,
Julian
Hi Zoo team,
I’m using Zoo Design Studio on Windows (desktop v1.3.5) and trying to import several STEP (.step/.stp) files that were exported from an external CAD system.
All of these STEP files:
  • Open correctly and show full geometry in an independent STEP viewer (BR3DViewer on Windows), so the files themselves appear valid.
  • Have reasonable sizes (including one larger assembly around 70–80 MB and several smaller subassemblies).
In Zoo Design Studio:
  • I add the STEP files to the project and see them listed under Project Files.
  • When I use Commands to insert a STEP file into main.kcl, Zoo generates an import “file.step” as aliasName line.
  • After rebuild, I see a red dot with the tooltip “import failed,” and no solids appear in the viewport—only the origin planes—even after zoom extents/fit view.
  • I’ve tried restarting, moving the STEP files from a cloud‑mapped drive to a local folder, and testing multiple STEP files; the behavior is the same.
Questions:
  1. What is the correct, recommended KCL syntax for referencing and displaying STEP files that are already in Project Files in the current desktop build?
  2. Are there known limitations or required STEP export settings (STEP AP version, solids vs. surfaces, size limits) that could cause an “import failed” message even when other viewers can open the file?
  3. If you’d like to inspect the actual STEP files, I’m happy to share them via your secure process once you send an email request, as I prefer not to post them publicly.
Thanks in advance for any guidance on getting STEP imports working in the desktop app—being able to bring these assemblies into Zoo is key to exploring design modifications.
Best,
Harley
I am still having an issue loading STEP files. Can I send a sample file for debugging? I have a post on the Support page but no one is responding. Shall I give up on this request? thanks
Hi Harley,
I will send you a support email where you can attach the STEP file then we can look into your issue.
Best,
Cameron
Annoying when Zoo just says import failed. Before another try, open the STEP once and check solids / units so the file itself isn’t already the blocker. STEP File Viewer Online: Open STP Files, No Account | CADProps
