Dumb question for a laymen…with regards to zookeeper AI. I am assuming the API/minutes are for calling the server and for the AI to complete the request correct? Does it also use those minutes to move/adjust a part that is already written and in place? for example I need to move a mounted light to a different spot on the model.
If so and I need to do this manually, do you have any tutorials to show me how to select a specific part, slice it off and post it to a new location?
Hey Brandon,
These are great questions and I’ll try to lay them out clearly.
When you have a Zoo Design Studio subscription (Free, Plus or Pro) the minutes are used only in the time that Zookeeper is working on the problem. It is free for you to personally design or adjust the model, but if Zookeeper does the adjustment that will use some of your minutes. In short, your minutes only get used when Zookeeper is actively working.
I’m not sure what your model looks like exactly, but here is a video on Moving and Rotating a model.
If you share some screenshots or the project files (as a zip) we may be able to help you out some more.
Best,
Daniel
So how does this relate to having the Pro version? Since API calls are pay-as-you-go, does Zookeeper to make/adjust my build cost me for any API calls if I just want it to make me a box? I understand if it needs to call a website or do a search for an image/specs on something specific that would be charged but the API calls within the main app itself is what confuses me.
I know its a little confusing because the term “API” can be overused so let’s drop it for now and just talk about “minutes.”
In Zoo Design Studio you can use Zookeeper. Depending on your plan, you have a set budget of minutes for Zookeeper to do its “thinking.” It doesn’t matter what task Zookeeper is doing during that time, it will use those minutes. So Zookeeper may look for images, create the model, move/adjust the part, but none of that matters for you. All that matters is that Zookeeper was thinking during that time.
Once you run out of minutes you are either stuck until they reset or you can opt into pay-as-you-go. If you are using pay-as-you-go you are paying for minutes Zookeeper is actively thinking. Again, it doesn’t matter what Zookeeper is doing during that time, if Zookeeper is thinking, you are being charged. Once Zookeeper finishes, the charging stops.
To use an analogy, imagine you got in a taxi and the driver said “For $20 I’ll take you anywhere I can drive to within 5 miles, and to go further it is $4/mile.” So you can ride 1 mile, 2 miles or 5 miles and they all cost $20. But say you want to go 7 miles, well that’ll be the $20 for the first 5 miles and then $8 for the extra 2 miles.
So what does this mean if you “just want it to make you a box”? It means that the entire time Zookeeper is thinking about making the box, drawing the box, taking snapshots of the box, your minutes are being used. The exact thing Zookeeper was doing during that time doesn’t matter. All that matters is that it was thinking. The second it stops and says “OK, here is your box,” you are no longer being charged.
That makes sense, thank you for the explaination. What am I most confused by is say I upgrade to PRO which gives me unlimited thinking time. What do I need to be mindful of with regards to the pay-as-you-go API parts?
Gotcha gotcha sorry I missed that part. The biggest takeaway is as long as you are only using Zoo Design Studio you never need to worry about “API pricing”. All you need to worry about is Zookeeper minutes.
Specifically, with Pro there will never be any pay-as-you-go charge for Zookeeper minutes since it it unlimited. You’d never run out of minutes so there wouldn’t ever be a pay-as-you-go charge. It’s like the taxi driver saying “For $100 I’ll drive you wherever you want to go no matter how far.” This FAQ item describes it, but I agree it is a little confusing.
If you ever decided to make your own app, that is when API pricing comes into play.
However, unlimited Pro will be going away soon. We haven’t landed internally on what the new limit will be, but it should still be more than enough to get large projects done.
OK, that makes total sense. Maybe it would help to word it in a way that says EXTERNAL API’s are billed at pay-as-you-go rates vs looping them in Zookeeper minutes, that would dispel some confusion and worry, in my opinion. In that case PRO makes TONS of logical and financial sense.
If you are going to change PRO from unlimited my suggestion (if I may) is 2400 minutes. That’s 40 hrs. and in line what I would expect a typical “PRO” to use for a single project.
I also would like to suggest a way that we can buy and bank Zookeeper minutes vs a monthly plan. I understand the reasoning behind the monthly plan as a regular predictable revenue stream don’t get me wrong BUT someone like me who might use this a couple times a year for 10-20 hrs. at a time for a project I would prefer to just buy a bank of minutes/hours and “top up” when I need more. That way I know what I have available or what my budget will be instead of an unknown cost depending on how well Zookeeper behaves.
Again, I am very impressed with the platform and was able to make a very detailed CAD rendering of a project that has been a napkin sketch for over a year for a 1/10th of a fraction of the cost an engineering company quoted me just to draft it.
Thanks Brandon, I’ve shared your suggestions with the team. Overall, I’m thrilled you’re getting a lot of use out of the product! Empowering people to design and solve problems themselves is what we’re all about.
