Hi,
I downloaded the modeling app for Windows but not able to login:
Error while trying to log in
Hi,
Hi! The typical workflow is that your browser opens. The website should have a title " Device Activation" and show you a 8 digit code. Did that happen?
If not, you can manually enter the code on this page Device Activation | Zoo after logging into zoo.dev.
Thank you! I’ll pass this forward to the development team.
In the mean time you can try to click “Sign in to get started” and then insert the code here in your browser (login if prompted): Device Activation | Zoo
