How to stop constant refresh/rebuild?
I am using the desktop version and on a local project. Every time I move my camera or if I come back to the application (not closed just switched to say google) it has to re-render/reload the model. Is there a way to stop this? I used Zookeeper to build it so I’m not sure if the multiple parts aren’t “welded” together so it has to reload them as if they are separate or what. Any thoughts?
We have a default timeout of the engine stream connection after 5 minutes of inactive use. After these 5 minutes when you come back to the 3D scene it must reconnect and reload the model since it was disconnected.
Makes sense, but why does it do it even when I just want to move the camera to see the project as a whole?
Huh, I looked at the code it is actually 1 minute not 5 minutes right now.
The stream should have a frozen image of the last frame from the stream. The entire 3D rendering is done on the cloud. If you want to move the camera you need a stream there and when it goes idle (disconnects) you do not have a stream.
In reality the idle mode is complete disconnection from a stream to free resources.
well 1 minute could explain why its lagging SO hard. I have a lot of parts and it takes FOREVER (more than 1 min) to load the rendering and then when it does the camera is zoomed in and so I have to move it/zoom out which causes it to completely re-render.
Yeah, that is a bad feedback loop. If you wait for render it doesn’t finish in the minute then you come back to start over again. I’ll talk to the team.
Does the team have a timeline on when they might be fixing the cloud timeout back to 5 mins by chance?
This issue is actually pretty bad UX. As mentioned, when the 3D scene is heavy (lots of pieces) it takes forever to render…so the user naturally just puts the tab in the background…when you finally remember to check it you go to check it and it starts building the whole process because the stream has stopped.
I might be a good idea to possible see if the code for the 3d geometry can be stored in the local storage that way the rendering can still show and be manipulated when it’s “disconnected” from the stream.
Some other ideas to speed this up, is let’s say if there’s a main.kcl that has 50 things inside of it. It might be a good idea to have a list of all the rendered items on the left side so the user can literally check the box for the items they do or DO NOT want to render instead of having to goto each KCL file. Thanks.
