I am using the desktop version and when I start my projects my ping is in the mid 30s and my connection is strong. Then after 20-30 mins my ping is now over 330 and the connection is “OK”. Any ideas on what’s causing the lag?
Just had a ping of over 600+…yikes
Trying to chase what’s happening here. What operating system and Zoo version are you on? Version should be in the bottom left of your application.
I am using windows 10 pro. I am running a Ryzen 5 5600, 32 GB DDR4 3600mhz, RTX 3060 12gb video card with highspeed cable internet in the Seattle, USA area. Zoo is 1.5.0.
I have made A LOT of edits with Zookeeper and am wondering if maybe the files are getting bogged down which is slowing down the whole process? I can submit a ticket if you would like to check the project.
@Jordan.Noone it must be my project size? I started a new one using the specs of the other one that was changed multiple times to test it and its not spiked at all and is loading much faster.
Thanks for your patience Brandon. We were able to trace your difficulty to a repeat-execution bug in our renderer. This will be fixed on Monday, as we try not to push engine changes over the weekend. I will send you a note when it is out, it will have a significant impact on performance for your models.
Great news! Glad I could stress the system enough to find it HAHA
Thanks for your hard work.
