Unable to Log In to https://dev.zoo.dev/ via Browser
Hi,
I’m encountering an issue where I’m unable to log in to the website at https://dev.zoo.dev/ through my browser. Has anyone else experienced this or know what might be causing the problem?
I’ve tried multiple browsers and cleared my cache, but the issue persists. Any help or suggestions would be appreciated!
Thanks in advance!
Hi Liam,
https://dev.zoo.dev/ is our test environment. You should be able to login at https://zoo.dev/
Cheers,
Max
Hi whenever i click on login there is no code showing in the browser, only greyed out
